yamadog1134 Posted June 5, 2005 Report Posted June 5, 2005 I just bought this bike, and it was running great. Then it started to cut out, so i put a new coil on it. Again it ran great for a bout a week then it started fireing on one cylinder, but still moved, the other cylinder fired off and on, now it is firing on the other clylinder i hav no idea what is wronge. It will start (its hard to but it does) both cylinder gets spark not as much as it should but some. I think it might be the cdi, but im not sure and i dont want to spend the money if its not that can some one help me. thanks yamadog1134 Quote
justinklumb29 Posted June 5, 2005 Report Posted June 5, 2005 did you buy a new coil or a used one? try switching the wires on your spark plugs around and see if it runs on the other cylinder Quote
yamadog1134 Posted June 5, 2005 Author Report Posted June 5, 2005 did you buy a new coil or a used one? try switching the wires on your spark plugs around and see if it runs on the other cylinder 377885[/snapback] i bought it new and yea that was the first thing i tried it dosent matter which wires are on which plug the lefdt clynder is the only one working today and tommarro the right one will work it seems like that is the way it works a diffrent one each day ne ideas? Quote
bansheefreak Posted June 5, 2005 Report Posted June 5, 2005 make sure your connection is good on the spark plugs box thingy... my bros banshee ran like shit till we checked there and had a lose connection then ran fine... Quote
cgamla Posted June 5, 2005 Report Posted June 5, 2005 Did you change the plugs. MIne will always foul the left side plug first for whatever reason and then it will ping every now and again on that side but mostly it is just stuck running on the right until I change the plug. You could try changing the plugs side for side and see if your missfire goes with the plug to the other side. Quote
yamadog1134 Posted June 10, 2005 Author Report Posted June 10, 2005 Did you change the plugs. MIne will always foul the left side plug first for whatever reason and then it will ping every now and again on that side but mostly it is just stuck running on the right until I change the plug. You could try changing the plugs side for side and see if your missfire goes with the plug to the other side. 378027[/snapback] yea there brand new plugs i have a new idea i think the throttle overide system is gone well not gone but busted im totally screwed i have no idea what im doing and i cant seem to figure this out ive replaced almost everythingn on this bike and it still runs like shit ne ides new coil new plugs new jets rebuilt carbs (done by a pro) new intake new cdi new radatior new clutch and cables brakes a ton of money and no results Quote
wayfst Posted June 10, 2005 Report Posted June 10, 2005 compression check, maybe a burned piston. Quote
mybanshees2fast4u Posted May 17, 2006 Report Posted May 17, 2006 Same scenrio with my $500 banshee, wouldnt run on both cylinders. Replaced every electrical compenent including the flywheel (thought the magnetics were whacked and werent sending a good signal). Pulled the head cylinders and pistons looked str8 but didnt have enough compression. Would pop start or kick start with a fuck load of kicks. It leaned out two weeks later melted a piston. New Wisecos and are in and waiting for replacement intakes to start it up. Definetly compression. Quote
dajogejr Posted May 17, 2006 Report Posted May 17, 2006 You did realize the last post on this thread was almost a year ago, right??? Quote
