hey everyone
i bought sone hoosier fklat track tires on douglas blue lables from my buddy today
he said to bore out the holes a few mil's and they will work fine
he said a few of the other racers around here have done it and there is no problem
anybody else do this ?? and what do i have to do ??
thanks
Matt
if the ex rim is the same as the 250 r(which i think they are) i have done it on 2 sets. I dont remember if the hole needs to go towards the center or away from the center but basically the hole just needs to be about 1/4 bolt size bigger. my friend did it at a machine shop he works at. It also needed a lil notch on inside of center for the lil tab that sticks out on banshee hub. I did the 2 nd set my self with a drill although i wouldnt recomend it on a good set of rims. these were a set of old paddles i found a a garage sale for 20 bucks.
the honda pattern is 110mm
and the yamaha is 115mm
can drill a second set of holes as well
378215[/snapback]
thats whjat id recommend. just offset them 45* from the other set and voila. you have interchangable tires/wheels.
