Well i put my lights back on last night just so i could do some night riding, well as soon as i flipped the switch on it would blow bulbs, tried hooked a different light up to it and it blew that bulb too, Are u suppse to get different bulbs with a timingf advance cause when i took my lights off i didnt have the timing advance yet
Is it blowing your tail light out also? if so find a new rectifier and put that on, that is the only thing that I know of that will cause your head lights to blow like that.
Sounds like your voltage regulator is not wired to your harness correctly! There is a blue wire for your taillight coming out of the harness I believe and a blue wire coming off of the voltage regulator be sure the blue wire coming from your voltage regulator is not connected to the tailights blue wire. Take a look at the schematic and you will see. The one time I did not have my volage regulator hooked up I blew through two sets of bulbs before I realized it was my voltage regulator.
