Well how hard is it to put a clutch in an 03 banshee, mines not holding through the powerband , all it does is slip so i gues its time for a new one. I usually do all my work myself but just curious is there is anything i should look out for when replacing a clutch
Its a very easy job. You should be in and out within an hour. Only thing to really look for is a worn clutch basket, or pressure plate. Make sure you get the alignment marks set correct as well before you put your clutch cover back on
