ok im retarted this is the first time ive takin the carbs all the way apart, and im trying to get the jetting right, i want to adjust the clips, where are they?? <_< heres a pictures anyone point it out to me? thanks
Not in your pic! ... They're in the top of your slides. ;)
Two screws hold down the stopper plate. Once they're out the needle will come out the same way.
Rare.
372538[/snapback]
ohhh its in that, haa thanks
having the clip on the top notch leans it right??
The higher on the needle you put the clip the meaner it becomes because this allows the needle to go lower into the main jet. But the lower on the needle you place it, when it comes to rest in the hole of the main jet it sits higher now and allows more fuel to go through thus making it richer.
Leanest
Leaner
Rich
Richer
Richest
And this is with the stock needle, after market (ie Dynojet needle) gives you more slots six I think. If this is wrong please anyone chime in, but I think it is right......... :cheers:
Leanest
Leaner
Rich
Richer
Richest
373136[/snapback]
thanks, to bad those little clips have wings, ha one flew across the garage but i gota new one
