jmoore Posted May 15, 2005 Report Posted May 15, 2005 I have a question about the service label. The manual says that if you use a non detergent motor oil, it must be SE, SF, SG or Higher. So would SA or SB be higher or how does that work. Reason I ask is that I found a non detergent 30 weight oil with a rating of SB and was thinkin of using it for my tranny.... Quote
quick-z Posted May 16, 2005 Report Posted May 16, 2005 I have a question about the service label. The manual says that if you use a non detergent motor oil, it must be SE, SF, SG or Higher. So would SA or SB be higher or how does that work. Reason I ask is that I found a non detergent 30 weight oil with a rating of SB and was thinkin of using it for my tranny.... 369533[/snapback] all I know is I use automatic trans fluid type f and never had a problem and its cheap $ Quote
05bansh Posted May 16, 2005 Report Posted May 16, 2005 Go with some Bel ray 80w. For 3.99 a bottle you cant go wrong. Quote
Banshee~ Posted May 16, 2005 Report Posted May 16, 2005 Go with some Bel ray 80w. For 3.99 a bottle you cant go wrong. 369909[/snapback] Thats what I use, I get mine for $5 a litter. Quote
RNBRAD Posted May 17, 2005 Report Posted May 17, 2005 This will help you understand API ratings. LINK Quote
