superbanshee03 Posted May 10, 2005 Report Posted May 10, 2005 question, I just bought some Shearers pipes and I wanted to know about what jetting to start at. I just got them yesterday and have to order some jets. I curently run 165 mains and 50 piolts with 33pwk keihins number 5 slides and not sure on the needle. I had t6 pipes, but I didnt have it diled in perfect. I just need a good starting point jets,piolets airscrew, needle, clip, slides, then I can take it from there. Does it matter what slides I run? Quote
white trash Posted May 10, 2005 Report Posted May 10, 2005 Thats probly real close. My set up is close to yours. (i have shearers as well) Im running 33's @ 900' about 70 degrees 168 main, cgl needle on the 4th clip down, 52 pilots, 1-3/4 turns out on the air screws. The 52 might be rich, but i put a 50 in mine and it didnt like it so i went back up Quote
superbanshee03 Posted May 10, 2005 Author Report Posted May 10, 2005 What slide are you running, mines a #5 or does it matter? Quote
white trash Posted May 11, 2005 Report Posted May 11, 2005 I am running 5's as well. I do know that the cutaway angle of the slide factors in, just couldnt tell ya where. Quote
hittintrees srh Posted May 11, 2005 Report Posted May 11, 2005 where did you get your sheares how much were they also how do they fit around your pod filters, if you have them that is Quote
white trash Posted May 11, 2005 Report Posted May 11, 2005 where did you get your sheareshow much were they also how do they fit around your pod filters, if you have them that is 367733[/snapback] I got my shearers from Jim at passion racing... he goes by passionRE here on the boards. 460 shipped. Mine fit great, no problem with hitting the filters at all Quote
wesw Posted May 12, 2005 Report Posted May 12, 2005 (edited) i wouldNT use a cgl its too lean on the bottom use a CEL adjust your pilot Edited May 12, 2005 by wesw Quote
