Toomey Banshee Posted May 9, 2005 Report Posted May 9, 2005 I just dug 2 ponds in my backyard. One is about 300 gallons and the other under 200 gallons. I have the smaller pond dumping into the bigger pond. I have a large box type filter dumping filtered water into the smaller pond with a pump in the larger pond feeding the filter. (Kinda hard to explain , but pretty simple if you know what I'm talking about.) I have to put the filter RIGHT up to the pond in order for the filtered water to dump into the pond, I tried to run lines to the pond from the filter and just dosent have enough power. The filter right on top of the pond really looks like shit too. Do they make a pump that will pump water from my filter, after its filtered a short distance? Maybe 7-15 feet. I need a fitting on both ends of the pump, intake and supply. Kinda long, sorry, wanted to explain. Quote
bigwill Posted May 9, 2005 Report Posted May 9, 2005 Apparently landscapers dont ride banshees-but as a home remolder-I would suggest a hidden Sump pump to move the water-there are plenty of different sizes.Sounds like you are the CONDO type Quote
applpro Posted May 9, 2005 Report Posted May 9, 2005 I just dug 2 ponds in my backyard. One is about 300 gallons and the other under 200 gallons. I have the smaller pond dumping into the bigger pond. I have a large box type filter dumping filtered water into the smaller pond with a pump in the larger pond feeding the filter. (Kinda hard to explain , but pretty simple if you know what I'm talking about.) I have to put the filter RIGHT up to the pond in order for the filtered water to dump into the pond, I tried to run lines to the pond from the filter and just dosent have enough power. The filter right on top of the pond really looks like shit too. Do they make a pump that will pump water from my filter, after its filtered a short distance? Maybe 7-15 feet. I need a fitting on both ends of the pump, intake and supply. Kinda long, sorry, wanted to explain. 366538[/snapback] Ive got a pond of about 2000 gallons. I use a Skippy filter (do internet search) that's fed by a submersible Tetra OFX 2000 pump. The filter box is set back about three feet from the pond-could be more if needed. The outlet from the filter feeds thru 2" PVC pipe into a waterfall stacked in front of the filter box (hides the filter. The other option you could use would be to move the filter further away from the pond & dump the outlet into a stream bed that would feed the ponds. Quote
KoooPSD Posted May 10, 2005 Report Posted May 10, 2005 I work for a landscapping company, but i have no experence with ponds. Quote
crbanshee Posted May 10, 2005 Report Posted May 10, 2005 only ponds i know about are bass ponds Quote
yamahanut98 Posted May 10, 2005 Report Posted May 10, 2005 out filter and pump in our little pond maybe (100 gallons) is submerged and then we run a clear line that comes in lengths of like 00 ft that hook out and we hide the line in rocks lining the pond and thats what runs ours sounds liek its what your looking for i think i picked it up at lowes for like 70 bux Quote
