i was just wondering what kind of signs there are for when your motor is going..
i bet alot of people on this site have replaced there heads/pistons/rings/cranks/
ect.. so you must know of some signs of parts about to go???
just wanted to know so i dont end up blowing up my motor to bad somday.
thanks
peace devin
loss of compression if your lucky-no warning on crank-bearing failure-ride till it dies-then rebuild at the NEXT level-your air filter maintence will determine how often you have to rebuild---but dont forget Murphys Law!!!!!!
horrid noises from the crankcase, knocking sounds in the clutch side. any grinding noises. anything out of the ordinary really.
or when its runs fucking unbelievably great. mine always seems to be running sumbitch, then throws a rod, or spilts a piston in two or something.
Just always keep an eye on your plugs to always make sure your jetting is good, check compression every once in a while, and hope a crank bearing doesn't go out, or something stupid like losing a circlip, you should be pretty alright. If something just plain breaks and you maintained everything well, it was just meant to be and you will have no idea. And it is usually true, your bike will run better than it ever has before right before something blows. banghead
