Limited_kid Posted May 4, 2005 Report Posted May 4, 2005 if i go fast on 6th gear the carbs leak on me whats the problem Quote
superchicken Posted May 5, 2005 Report Posted May 5, 2005 im sorry i just find that funny. but,witch side is it? Quote
MDS2106 Posted May 5, 2005 Report Posted May 5, 2005 (edited) now that i reread his post it is funny Edited May 5, 2005 by MDS2106 Quote
NEVER SATISFIED Posted May 5, 2005 Report Posted May 5, 2005 (edited) is it warm when they leak on you? jk jk... where does it leak from.. a intake cage, the overfill tubes, gas petcock hoses.. Edited May 5, 2005 by NEVER SATISFIED Quote
Klotzban1 Posted May 10, 2005 Report Posted May 10, 2005 If your carbs are leaking ....may need a new float bowl gasket and you might need to check your floats to see if they are sticking. If this happened after you removed the carbs...just tap the sides of your carb lightly and turn your fuel cock on and see if it drains out the plastic flow tubes...if not...your floats are working. Quote
Wallynut Posted May 10, 2005 Report Posted May 10, 2005 How do you know your leaking fuel while driving in 6th gear? You would be leaking fuel at just about any gear or even just sitting still, in fact, most will only find that fuel is leaking while bike is sitting and not running becuase the float is out of adjustment or valve has an obstruction (dirt). Quote
