ninja11zx Posted April 22, 2005 Report Posted April 22, 2005 i was riding my banshee tonight and every thing was ok untill i was downshifting to first and it wouldn't go in.when i got home i checked it out and it will only go into 2nd and 3rd.it won't go down into first or up into 4th.any one have any ideas?it was fine before this and wasn't beating on it.wanted to go to the dunes this weekend.i guess thats out.what could it be? thanks Quote
BLUE BANSHEE 20 Posted April 22, 2005 Report Posted April 22, 2005 SOUNDS LIKE YOU HAVE GEARS BUSTED .BEEN THERE AND DONE THAT. Quote
sheefreak Posted April 22, 2005 Report Posted April 22, 2005 Unfortunately you won't be able to tell much untill you split the cases. Could be busted gears, bent shift forks, could be bound up on the shift drum, really hard telling. Quote
ledofthezep Posted April 22, 2005 Report Posted April 22, 2005 Sounds to me like your shift fork is bound up. Tip it up on its side & pull the clutch cover off, you'll probably(hopefully) find that the shift forks popped out & is bound up on the shift star. Kind of hard to explain, but if you look you'll see what I'm talking about. If so, take a screwdriver & get the forks back into place on the shift star. For a temp. fix to get you through the weekend, after you get everything un-bound, take your shifter off & throw a rubber washer on the shaft, followed by another one or two and put the shifter back on. This will help to hold the shaft over in hopes that the forks don't pop out again. Quote
pimp559 Posted April 22, 2005 Report Posted April 22, 2005 I had that happen and it was only a $2 part. If you take the clutch cover off you will see where the shift rod pivots on a bolt that has a flat head. Behind the flat head is a nut with a tab washer behind it. Most likey this nut has come loose or the weird looking bolt with the flat head broke. I couldn't get that bolt in at the stealership before I went riding so I just took a bolt of that size and cut the head of it off. After I cut the head of it off I used a hack saw and cut a line in top of the bolt to make it a flathead bolt. Whala, your back riding for under $2. Quote
ninja11zx Posted April 23, 2005 Author Report Posted April 23, 2005 Found It,i split the cases and found that one of the gears siezed on the shaft.it wont slide on the shaft.glad i have a spare trans.forks and everything else looked like new.thanks for the replies. Quote
