ive always used either yamabond or three bond grey when i do the cases.now i do know after you assemble every thing and get her running ,the oil does go a little low the first few times you go riding,i think because it lays up on the tranny gear shelfs.so,why exacly do you think its burning oil?
I'm hoping that its just leaking thru the case....it was buning oil so bad i had it basically sprayin out the exhaust. I will find out monday when i get my new crank seal... Hope it fixes it this time....This Shee has been a money pit... :wacko:
no...its definitly gear oil....i burned off about a half quart in an hour...i just still cant believe that it could all be just seeping thru the case halves
if you're losing that much into your cylinders and it's pushing out the exhaust wouldn't the plugs be fouling or running like shit? sounds more like a rich fuel ratio, and a leak somewhere to me. are you sure it's not leaking where the case halves meet, or out your drain plug or something?? :confused:
40:1??????????? I dont think thats too rich. Its gotta be coming from where the case halves meet...i will know monday when i put it all back together i guess
