My 91 Motor has A Pro Design Cool Head with 20CC Domes.Power reeds. A Keihin 33PWKmm Carb kit. Stage IV manifolds, Tommey pipes etc.
Should I be running pump gas or Race gas? I know the guy b4 me had taken the domes out and is running race gas but I was considering putting the domes back in.
Not having the domes in would require race gas?
Advice appreciated
Anthony
I don't understand what do you mean he took the domes out? you'd have to replace them with another set of domes if you took them out. Does it have the 20's in it right now? What's your elevation? Any timing advance? Have you checked your compression? If your compression is over 160 you need race gas.
If the 20CC domes are in it now. And I run both at 1300 Feet and at sea level. Would it be different for both.
As far as compression I know it has a .50 over wiseco and I would have to test the compression The quad is new and I havent had a chance to Mess with it yet.
From Noss's web site it appears that at sea level you'd need race gas since compression would be near 169, at 1300' you'd be ok on premium pump gas. Noss's chart tends to be conservative. But since your machine isn't new you might not have that high of compression. You need to check it and if you're near 160psi run race gas.
SILLY BASTARD, SHEES ON RACE GAS ARE FOR MEN! NOT BOYS.
Ya need a compression tester, i think i got one, the one from my Probe, but i have the adapter....
oh and stop sniffing gas, it will turn your hair red like your brothers....
RACE GAS OR PUMP YOU NO LONGER HAVE THE FASTEST QUAD ON SOUTHVIEW!
YEA WE WILL DEF HAVE TO DO THE COMP TEST.  THE UPPER HALF CAN WAIT BUT THE CLUTCH AND BASKET WILL HAVE TO BE DONE.
353471[/snapback]
:yank::yank::yank::yank:
bring it over when youre ready, brang my shit home from upstate, you changing clutch disks and springs too? get a new cable and get a e-brake block off and new clutch lever, i'll have it all done in like an hour
yea I have everything except the cable and the lever is brand new. We can go riding i know a place out east 5 acres atleast sand jumps and 1 long trail. You wont have to worry about your shit gettin takin away.
