XxMeltIcexX Posted April 7, 2005 Report Posted April 7, 2005 I got a new seat cover, didnt get a cheap one at that, and i cant get the fucker on. Started from the front to the back, friends told me to start from the back this time.. Its all loose up by the front of the seat. Does anyone know how to put these fuckers on?? My stapler gun has to be positioned perfect to work, its not the greatest stapler. Thanks, Eric Quote
mxbanshee Posted April 7, 2005 Report Posted April 7, 2005 You bet... Use a hair dryer or heat gun. Heat it up real good that way it will strech and get bigger. Then when it cools is shrinks down nice and tight. Yes, start at the top and work your way down pulling real tight. This should do the job!!! Check out my job... You can bounce quarters on it! Quote
RNBRAD Posted April 8, 2005 Report Posted April 8, 2005 Well here's my advice, been there many times on many quads. If you have graphics, make sure you line them up, frequently taking seat and placing on quad to see where your at. First put the cover on, get a feal how your seams will line up and make adjustment accordingly. Unfortunaley not all seats are made for a real tight fit according to where the rear seams are at. It really helps to have another set of hands. Take the front pulling taught and staple just a couple to hold in place. Now the rear of the cover, do the same but make sure and get it fairly tight, not a bad idea to actualy make the seat flex or pull the front of the seat making it angle more towards the back. Staple the back with just a few staples to hold in place. Now work the sides, pulling down like a mofo and make sure to pull evenly on both sides. Don't pull to hard on one side and not leave enough material for the other side, seat cover will be uneven. Best thing to do is collapse the foam in the seat center even to the sides you are stapling. Work your way from the middle to the corners. Now go back and reinforce your work with more staples, Good luck, if all else fails, send it to me, I'll do it for you. Also I good idea to use stainless or corrosion resistant staples. Quote
XxMeltIcexX Posted April 9, 2005 Author Report Posted April 9, 2005 Well here's my advice, been there many times on many quads. If you have graphics, make sure you line them up, frequently taking seat and placing on quad to see where your at. First put the cover on, get a feal how your seams will line up and make adjustment accordingly. Unfortunaley not all seats are made for a real tight fit according to where the rear seams are at. It really helps to have another set of hands. Take the front pulling taught and staple just a couple to hold in place. Now the rear of the cover, do the same but make sure and get it fairly tight, not a bad idea to actualy make the seat flex or pull the front of the seat making it angle more towards the back. Staple the back with just a few staples to hold in place. Now work the sides, pulling down like a mofo and make sure to pull evenly on both sides. Don't pull to hard on one side and not leave enough material for the other side, seat cover will be uneven. Best thing to do is collapse the foam in the seat center even to the sides you are stapling. Work your way from the middle to the corners. Now go back and reinforce your work with more staples, Good luck, if all else fails, send it to me, I'll do it for you. Also I good idea to use stainless or corrosion resistant staples. 351666[/snapback] Man, sounds hard... I do have an extra pair of hands, it feels like theres not enough damn foam under the thing, but i havn't tried to use a heat gun or hair dryer yet, and i'm gonna get a new stapler too. If shipping wasn't hard i'd send it to you right now! Thanks Eric Quote
RNBRAD Posted April 9, 2005 Report Posted April 9, 2005 Man, sounds hard... I do have an extra pair of hands, it feels like theres not enough damn foam under the thing, but i havn't tried to use a heat gun or hair dryer yet, and i'm gonna get a new stapler too. If shipping wasn't hard i'd send it to you right now! Thanks Eric 352450[/snapback] We'll if it comes to it, I'll definitely take care of it for ya if it gets too hard. Quote
badcompany Posted April 9, 2005 Report Posted April 9, 2005 Save some time and take it to an upholstry shop, theyll pull it nice and tight and charge you like 10 bucks. Quote
NEVER SATISFIED Posted May 25, 2005 Report Posted May 25, 2005 i just put my alba one on and are you suppose to take the original off?... Quote
RNBRAD Posted May 25, 2005 Report Posted May 25, 2005 i just put my alba one on and are you suppose to take the original off?... 373647[/snapback] Yes. Quote
NEVER SATISFIED Posted May 25, 2005 Report Posted May 25, 2005 Yes. 373681[/snapback] im a dumb mofo!!!! i did mine in 30 min.. bet it woulda been faster had i takin that thing off... Quote
racer714 Posted May 25, 2005 Report Posted May 25, 2005 I got a new seat cover, didnt get a cheap one at that, and i cant get the fucker on. Started from the front to the back, friends told me to start from the back this time.. Its all loose up by the front of the seat. Does anyone know how to put these fuckers on?? My stapler gun has to be positioned perfect to work, its not the greatest stapler. Thanks, Eric 351323[/snapback] Dude, your post couldn't have better timing! I got a new one last weekend and am having EXACTLY THE SAME PROBLEM Quote
racer714 Posted May 25, 2005 Report Posted May 25, 2005 Save some time and take it to an upholstry shop, theyll pull it nice and tight and charge you like 10 bucks. 352507[/snapback] wORD ON THIS, i JUST CALLED A SHOP AND $15 LATER HE INDICATED IT WOULD BE TIGHT AS A MOFO!! Quote
2004LEBanshee Posted May 27, 2005 Report Posted May 27, 2005 Save some time and take it to an upholstry shop, theyll pull it nice and tight and charge you like 10 bucks. 352507[/snapback] yup an easy 10 well worth it. Quote
Wallrat Posted May 28, 2005 Report Posted May 28, 2005 I spent a total of 15 minutes on mine. Then I took it to the upolstry shop and handed over $10. I'd have paid $30 for the PITA it saved me. They had it back in my hands in about 10 minutes. F*ckers! Quote
Animalman294 Posted June 16, 2005 Report Posted June 16, 2005 Man, you guys have me rollin' half the time. Some of the things that people do when they don't quite know what they are doing is hilarious . But hey, at least you are trying, but I like the upholstry shop idea better. No offense guys, but you are funny as hell . Quote
