Bansheeracer Posted April 4, 2005 Report Posted April 4, 2005 ANYONE USING A TRINITY HEAD ON THE CHEETAH CUB? I HEARD IT DOESNT WORK VERY WELL.. ANY TRUTH TO THIS? WHAT SIZE DOME ARE YOU USING? Quote
Brian G Posted April 4, 2005 Report Posted April 4, 2005 there is no problem it will work just as good. I have dynoed both the trinity and pro design on a cub and they were the exact same. If anything the trinity is better because it uses the studs to hold the domes on. Some people have problems with the domes lifting on the pro designs. Hope this helps. Quote
Fireman-hott Posted April 5, 2005 Report Posted April 5, 2005 domes lifting up on the pro design? I run a pro design and have never heard of this nor seen it. I know its jsut like the noss head with the way the domes are kept in there and if you don tline that notch up correctly they will not seat right, but hell you should be able ot see that, than when you torque it down the bottom half of the head holds the domes in place. Anyway back to the original post, you should have no problem running the trinity head, non at all. Make sure your domes are cut correctly for the bore size if your running anything other than a stock bore/stock stroked cub. Quote
