i just bought some 36mm kehin pe carbs the slides will close completely when throttle cable is not connected but when the cable is connected it will only close about half way
346242[/snapback]
is this when the cable is connected to the carbs and connected to the thumb throttle at the same time? if so then you may have to adjust the cable at the thumb throttle body. also, do the carb caps have an adjustment on top of them? if so then they may need adjusting as well.
Edited by cam2
Did you use the stock cable, or the one that came with the carbs? My stocker (well, not stocker, but twist throttle cable for stock carbs) had the same problem. I put on the cable that came with the carbs and no problem.
