Banshee~ Posted March 26, 2005 Report Posted March 26, 2005 Can someone download the .pdf from fmf.com for the install on the pcII silencers and turn them into .jpg or something for me? Quote
DIRTBIKEZ Posted March 26, 2005 Report Posted March 26, 2005 Can someone download the .pdf from fmf.com for the install on the pcII silencers and turn them into .jpg or something for me? What part of the instructions do you actually need? Installation is a breeze. Quote
decon Posted March 26, 2005 Report Posted March 26, 2005 (edited) I it in .jpg form but cant upload it. i will email it to you. Edited March 26, 2005 by dEcon Quote
locogato11283 Posted March 26, 2005 Report Posted March 26, 2005 shouldnt be too hard. what do you need to know? Quote
Banshee~ Posted March 26, 2005 Author Report Posted March 26, 2005 Theres 4 rubber pieces, 2 some crazy piece, some bolts, and no instructions [email protected] ---decon...thanks Quote
decon Posted March 26, 2005 Report Posted March 26, 2005 Theres 4 rubber pieces, some crazy piece, some bolts, and no instructions [email protected] ---decon...thanks 345259[/snapback] sent. no problem Quote
Banshee~ Posted March 26, 2005 Author Report Posted March 26, 2005 sent. no problem 345263[/snapback] decon i got that sheet with the pipes, but they gave me 10 peices off hardware and I can put them on there about 200 different ways Quote
Banshee~ Posted March 26, 2005 Author Report Posted March 26, 2005 could someone take a picture of there silencer mounting brackets...I just want a pic of the hardware. Quote
. Posted March 26, 2005 Report Posted March 26, 2005 Theres 4 rubber pieces, 2 some crazy piece, some bolts, and no instructions [email protected] ---decon...thanks 345259[/snapback] there's 2 mounting tabs, one goes into the grab bar, the other into the frame. Put a rubber piece on each side of the tabs (I think the crazy pieces are like tubes that the bolts go through?), anyway, the 4 rubber pieces go on either side of the tabs, and then the bolts go through them Quote
Banshee~ Posted March 26, 2005 Author Report Posted March 26, 2005 there's 2 mounting tabs, one goes into the grab bar, the other into the frame. Put a rubber piece on each side of the tabs (I think the crazy pieces are like tubes that the bolts go through?), anyway, the 4 rubber pieces go on either side of the tabs, and then the bolts go through them 345471[/snapback] thanks, "." that did the trick sst's are a bitch to get on, the pipe clams are rubbing on the airbox. Now Ive got to jet the beast Quote
