i run 93 octane in my shee at the moment with a cool head, bills pipes, and a K&n. i was wondering if changeing dome size the same as shaveing the head on a stock shee head i mean does it add compression and what not so you have to run race gas i dont know what size my domes are in my head right now and im at sea lvl i was thinkin about changeing them out to run race gas if it was a good performance adder.but im still new to most of this stuff so any advice id appreciate.thanks
344489[/snapback]
Noss Machine has a chart on their website that gives estimated cranking pressure with different dome sixes. I think race gas is required on anything over 160 lbs of cranking pressure. :bolt:
At sea level, you need to run more octane than pump gas probably with domes smaller than 21cc. You will increase compression with smaller domes.
344596[/snapback]
While we're on the subject, Dave. ... In the UK, (which is mostly ridden at below 1000ft), where do we stand on limits of dome size/ cranking pressure with our pump gas which has an Octane level of 97 (Unleaded)?
Rare.
i had no problem runnin 20cc at sea level on 92. any thing smaller than that definately run race gas.
If your octane numbers correspond to those in the U.S. you should be able to run 20cc domes with no problem.
344489[/snapback]
how do you like the bills pipes? and how do they sound
