j28d Posted March 21, 2005 Report Posted March 21, 2005 Hey, I bought a used pro design cool head yesterday that came with 19cc domes. The shop I bought it from said it would use the stock studs? Anyhow, I have a stock motor so will it last if I just use Cam 2 racing gas? I'm approximately 1000 ft above sea level and have some kind of aftermarket pipes(not sure what they are and they have no identifying marks). Also, I bought a 2-1 35 mm carb setup over the winter and haven't had a chance to put it on yet. I got the basic jetting setup from rocketpig, 52 pilot, DEK needle, 190 main before getting the head. Should I use this jetting to start after I install the head? Thanks for any help you can give me. Quote
GYTWYPT Posted March 21, 2005 Report Posted March 21, 2005 Pro Design cool heads do not use stock studs. They need to be longer. Quote
