tsufilmz Posted March 17, 2005 Report Posted March 17, 2005 (edited) ok i have a 01 shee that has pro circut pipes and is jetted to 300 mains stock pilets. I live in Michigan. now it starts and runs but i only get the left to fire. itl fire's on the right every now and then but when it dose it go's crazy. if i hit the gass it will fire also. i had reed spacers and boost bottle on but took them off. I happend to just replace the needle on the right cuz i bent the old one. what do you all think it could be? Help!!!! i want to go riding next week Thanks Jeff Edited March 17, 2005 by tsufilmz Quote
FIRST BANSHEE Posted March 17, 2005 Report Posted March 17, 2005 make sure you have a good connection at the coil, check spark plug caps, is your tors still hooked up, if it is check the throttle switch, carb switches, make sure you have a good ground. Quote
fastbanshee4u Posted March 18, 2005 Report Posted March 18, 2005 ok i have a 01 shee that has pro circut pipes and is jetted to 300 mains stock pilets. I live in Michigan. now it starts and runs but i only get the left to fire. itl fire's on the right every now and then but when it dose it go's crazy. if i hit the gass it will fire also. i had reed spacers and boost bottle on but took them off. I happend to just replace the needle on the right cuz i bent the old one. what do you all think it could be? Help!!!! i want to go riding next weekThanks Jeff 340857[/snapback] Switch the plug caps and see if it goes to the other side.This will tell you if it is spark or not. Have you changed plugs lately. Possible problems spark fuel delivery cranks seal head gasket leaking compression Good luck Quote
rocketboy Posted March 18, 2005 Report Posted March 18, 2005 Switch the plug caps and see if it goes to the other side.This will tell you if it is spark or not. Have you changed plugs lately. Possible problemsspark fuel delivery cranks seal head gasket leaking compression Good luck 340878[/snapback] this is good advise,especially the switching plug caps idea Quote
tsufilmz Posted March 18, 2005 Author Report Posted March 18, 2005 (edited) I just put new plugs in. should i need to move needle in the clip?Thanks alot will try it out. Jeff Edited March 18, 2005 by tsufilmz Quote
