Just wondering if anyone knows if you can run a RZ flywheel with a banshee stator. About the onlyl thing i see that looks diffrent is that the 2 pickup tabs on the flywheel are a little longer than my stock banshee ones.
thanks
I heard it will work but you have to change the timing ALOT of degrees. If you compare the 2, you'll see the pickups are in a differnet location compared to the keyway.
337972[/snapback]
well i compared the 2 the pick ups are centered in the same location in relation to the keyway, but like i said they are just a little longer.
Anyway i decided to just go ahead and pull my banshee flywheel and send it, but while it is out i plan on just trying the RZ flywheel on the shee. If anyone is interested let me know and i will post if it works or not.
thanks all
Go for it, it can't hurt to try.
338301[/snapback]
Wellllllll.
I slapped it on there today and kicked on it for a little bit. It did not seem to like it the +5 advance i had. kinda coughing instead of starting. Fortunaltly i have the easy adjustment on my plate. Just have to loosen a couple allen heads and move the pick up coil. So i figured since the tabs where a little longer i probably had to much advance. So i backed it up to around stock or -1 and it started right up the first kick sounded good. I should have let it be but i wanted to see how far i could go so i got it started up around +2... not bad tried a little more got the pick up coil a little close nicked it a couple times but it kept running, so i adjusted it and now the damn thing wont start for nothin. took the plugs out and they where wet. Didnt have any new ones laying around so i tried to clean them off and stick em back in but still nothing. I hope i just fouled the plugs but i think that is wishful thinking. Not real sure what happend.
But anyway it doesnt seem to take much to get a RZ flywheel to work. Just dont need any advance to speek of. Maybe 1 or 2 deg tops.
