Capone Posted March 1, 2005 Report Posted March 1, 2005 (edited) I have a cool head with 18cc domes, and wiseco's. It seems like there is no clearance as it is between piston & head.. how would a 5mm stroker work? thanks. btw, stroker newbie, if ya can't tell....lols. Edited March 1, 2005 by VitoBanshee Quote
locogato11283 Posted March 1, 2005 Report Posted March 1, 2005 first off i dont think youll hear much if anything about a 5mm stroker. it generally goes 4,7,10 and on up. 4 mm is the most common. to allow for the extra stroke you can cut the domes, which is the preferred method or you can use a spacer plate at either the top or bottom of the cylinders. Quote
racer Posted March 1, 2005 Report Posted March 1, 2005 yeah, loco is right. the only time youll see 5mm is in a longrod motor. this is when the crankshaft has 5mm longer connecting rods on it. it doesnt give much of a powergain, but it does decrease wear on your pistons. in this case to allow for the extra length you run a special series piston. the wiseco 795 is what you need to run, if this is the crank you own, or just want to own. Quote
Ducman Posted March 1, 2005 Report Posted March 1, 2005 Any added stroke more than +4mm and you have to have the stock cases trenched so they crank wont come in contact with the case. This adds a decent amout of $ to build a stroker motor. If you have to trench the cases, might as well go with a +7mm crank. Also you'll find the best deals (around $450) on the wiseco +4mm stroke +5mm long rod crank. Thats why most people run the +4mm crank. The only place I have seen a +5mm stroke crank in on banshee superstore.com. Theres a lot of other expenses that go with a 4mm strolker, ie stroker specific porting, domes, ect. Theres a decent amount of stroker info on past threads in the HQ. Quote
jinx44 Posted March 2, 2005 Report Posted March 2, 2005 I know of a 5mm stroker. You don't have to trench cases if you clearance the rod. 4mm is a lot easier to find, cheaper, and makes the same power. Quote
