PUSH THE THROTTLE,
Use a product called Sil-Glyde, you can get this at most auto parts stores (NAPA # 765-1351). Just put a few small dabs of this grease between the two lips of the seals.
On the ignition side, the writing on the outer rim of the seal faces out. On the primary side, the castle shaped side of the seal goes next the bearing.
Ron
