AtvStunter Posted February 19, 2005 Report Posted February 19, 2005 well today i was driving the shee and it went like a grinding sound on the right cyclinder .. i pulled the spark plug out and there is metal on it . so next i took the head off and the piston looks fine kicked it over looked fine. then i went to kick it again she will not kick for anything.So what can be wrong ? Quote
locogato11283 Posted February 20, 2005 Report Posted February 20, 2005 you need to pull that cylinder off and see what is broke. hopefully its only a piece of the piston. after you get it pulled off check back here with what happened and we can help you decide what to do with it. id be willing to bet its just a piece of the piston, but that can also mess up other shit. Quote
kw04 Posted February 20, 2005 Report Posted February 20, 2005 sounds like it might be the crankshaft. same thing happened to mine. sucks big time. Quote
