I'll be next door to him too!!!!!!!!!
318798[/snapback]
Be careful of him. He'll get you hung over, then film you the next morning!!! Ask Cotten-eyed-Joe... :rotflmao: Or Reas... :rotflmao:
Gang,
I've been seeing various posts here and in other threads and I never see anyone recommend pilots over 30.
My buddy (long time MXer) helped me jet my 'shee (and his...he got the same pipes). I have Pro Circuit pipes and single K&N/ProFlow, otherwise stock. We ended up using 32.5 pilot jets. Is that just way off the scale? I'm running 310 mains (he said the plugs looked tolerable with 300s but that it smelled lean when riding behind me :confused: ) It also has an Alba needle, but I didn't write down which clip we put it on. Slide gap was .043". I also didn't write down how many turns out the airscrews were set.
But does a 32.5 sound reasonable? My bike runs great, but it does smoke like a mo-fo when it's cold, something my older bike didn't do nearly as much.
Thanks!
_dennis
Pc pipes like a richer pilot compared to most others. If your shee runs great and idles great, then I wouldn't worry about it. If your really concerned, then do a leak down test to see if you have an air leak..
