I'm waiting on my T-5's to get here. Was about to order my jets and K&N when I found a couple of good prices on some 2 into1 intakes and 38mm carb with K&N on-carb filter. My question is would this be too much for a stock motor? If not, will it really make that much difference on my bike or should I just rejet my stock pair and spend the money elsewhere? I will be ordering new reeds also-either Delta 2 or TRD's........
38 is pretty big. It would work but the bottom end is gonna be choppy. Most people that go single carb use a 33mm for stock porting or a 35mm if they have/are getting some porting done.
I have all bolt on mods, pipes, reeds, milled head, +4 timing, cv intake with a 38mm. I had a 35 on it and a 38 for my 250r, so i tried it and kept the 38 on the banshee. It's a little softer on the bottom but pulls better on top. I'm happy with it. :headbang:
Ah no worries then. Although you might wanna hold out for a 35 if your planning on getting it ported. Not gonna make a huge difference but if you get ported and run a 33 you might lose a hair off the top.
