yes i know it has not a thing to do with a banshee but on my new yfz450 when it gets hot the pipe turns bright bright red what is the problem??? thanks
310516[/snapback]
The problem is you only make power 1 out of 4 revolutions causing your pipe to be imbarressed...
:P
seriously is it running good, if the choke isn't working properly it could cause an overrich condition, causing the pipe to turn red. have you done any mods.
They come lean from the factory.
Try the dadog yfz450 page they have lots of good information.
But dont do the cam mod since its bullcrap and will destroy your engine.
310516[/snapback]
I HAVE A BANSHEE NOW BUT I HAD A RAPTOR BEFORE I HAD STAINLESS PIPES ON IT AND IT TURNED RED TOO U COULD ONLY NOTICE IT AT NIGHT WHEN I WAS IDLEING I ASKED AROUND AND WAS TOLD THATS OK AS LONG AS YOUR JETTED RIGHT DO A PLUG TEST AND IF NEEDED REJET
