re-jetting for switching oil
If anything you will be a little rich, so I would get it switched over and run maybe a 1/4 tank through it then put in new plugs and do a plug chop. Might need to go down 1 jet size, JUST GUESSING.
Good luck-----Josh
ok thanks for the replies ill go ahead and try it out and see how shee runs. One other question, i need to replace my tranny oil because its pased due for new stuff but the only 10w30 i could find without the "energy conserving" label was the high mileage that had other additives in it. i did find 20w50 with out the energy conserving label, will that be okay to use?
310018[/snapback]
I wouldn't use 20w50 due to how thick it is...may not lube the clutch as well & may make it a bit harder to shift. With my stock clutch I always ran Valvoline 10w30, never tried the high-mileage shizzle though. :shrugani:
