I just put a set of RDZ In Frame Drag Pipes on my 05 Shee. I plan on sand dragging in 300ft and 400ft. Did i make a good choice???
Also, my bike is stock right now, not for long, but for now. The stock jetting for the 05 is a 200 main, i went up to a 220 main, is that good???
I'm not positive but I believe the RDZ inframes are the same as the Sheerer in frames (at least they look that way to me)which should be a good pipe for drag racing :headbang: , others here should be able to tell you more. For jetting you will definetly need bigger jets. My guess would be around a 280 or so with stock air box and up around 320 will filter mods(either K&N pods or K&N and an airbox adapter) which you will want. Yamaha had their head up their rear when they designed the airbox and filter setup on these things.
Anyway always remember to check the plug when your jetting
(white=lean---black=rich---tan/ brown=perfect)
Good luck-------------Josh
