01bansheefox Posted January 18, 2005 Report Posted January 18, 2005 Big difference or do tires not matter that much? I have 22's right now but saw some 18's im in love with........... Speed going to drop that much? Quote
fixitrod Posted January 18, 2005 Report Posted January 18, 2005 All you have to do is change your gearing to compensate for the speed. A new front sprocket will make that up. Bad thing about 18's is ground clearance. That's about it. Good thing about 18's is weight. Your suspension should work a little better with the 18's too. It's about one tooth per tire size so if you want to keep close to the same gearing that you have now, go up to teeth bigger in the front. If you have a 13 tooth in the front go 15 with the 18 inch tires. Quote
01bansheefox Posted January 18, 2005 Author Report Posted January 18, 2005 I have 16 up front now Quote
fixitrod Posted January 18, 2005 Report Posted January 18, 2005 With 22 inch tires. Wow. Well, try the 18" and see what you think. What are you running for motor mods. Quote
01bansheefox Posted January 18, 2005 Author Report Posted January 18, 2005 Wouldnt you like to know hehe just kidding well i did have a big bore 409, full drag port, dual 35mm but.... that motor is gone now and have nothing but a .60over port/polish/milled head/intake/pipes Quote
banshee tuner Posted January 18, 2005 Report Posted January 18, 2005 If clearance is not an issue go for the 18's and play with the gears. Quote
kenr74 Posted January 18, 2005 Report Posted January 18, 2005 If clearance is not an issue go for the 18's and play with the gears. 308528[/snapback] It depends on where you are riding. I just got rid of my 18" Holeshots for some 22" Sur traks and couldn't be more happy. That gives you another 2" of space between your rear sprocket and ground. That can be the difference between walking or riding back to the truck. It also means I don't have to change my gearing everytime I throw on the 22" paddles. Quote
banshee tuner Posted January 18, 2005 Report Posted January 18, 2005 That's why I included the part about if clearance is not an issue. Quote
01bansheefox Posted January 18, 2005 Author Report Posted January 18, 2005 Hmm well they also make the tire in a 20'' but on the 18 it has that super low profile and thats addicting looking. Quote
H250RHATER Posted January 18, 2005 Report Posted January 18, 2005 Hmm well they also make the tire in a 20'' but on the 18 it has that super low profile and thats addicting looking. 308580[/snapback] 18" feels so much better to ride on too 20" feels high im not into theat size unless its stright wood riding for me which its not so i ride 18" turfs im satisfied Quote
Banchetta Posted January 19, 2005 Report Posted January 19, 2005 The 18's will give a better lower center of gravity. Your cornering will beneifit and will have less tire roll in the corners..If you have no clearance issues and don't drag that much, then go for it..The 22's will hook better, but are worse in the corners...What's more important to you?? Cornering or traction? Quote
01bansheefox Posted January 19, 2005 Author Report Posted January 19, 2005 Probably traction truthfully but im also doing this shee from the frame up so i got alot of bling and the 18s will bling bling more Quote
NYCBanshee7 Posted January 19, 2005 Report Posted January 19, 2005 Wouldnt you like to know hehe just kidding well i did have a big bore 409, full drag port, dual 35mm but.... that motor is gone now and have nothing but a .60over port/polish/milled head/intake/pipes 308524[/snapback] With all that power, 18's will probably just spin and spin all the way through 6th gear. I have Fatty's and V-force reeds, and my 18's spin up to 3rd on the STREET. Quote
fixitrod Posted January 19, 2005 Report Posted January 19, 2005 If you want bling you can get 20 inch tires and 10" rims instead of the 9" rims too. The look more low profile then with the 9" rim. Quote
01bansheefox Posted January 20, 2005 Author Report Posted January 20, 2005 If you want bling you can get 20 inch tires and 10" rims instead of the 9" rims too. The look more low profile then with the 9" rim. 308889[/snapback] sooo like a 20x10x11 Last numbre is the width right? Quote
