I had a rattling noise in the clutch area so I replaced the basket since there was slack on the starter gear. Installed a new hinson basket and spacer on the main shaft. Put it back together and still has a rattling noise in the clutch area. The rattling goes away when the clutch lever is pulled in. What would be causeing this noise? Should i worry?
Edited by hotrodbanshee
I've had that noise for 6 yrs. Still there after basket and new plates. Yes goes away when clutch is pulled in. Never a problem though.
i see where you only put the basket it. i put the whole system in. the basket, hub, pressure plate. for some reason the plate hits and rubbs the clutch case.
have you checked your oil. mine had metal shaving in it. from rubbing on the case.
to solve i took a air disc sander sanded on the case where the clutch cover bolts are thru the case about 1/8 if that gotta watch out and not remove too much
stopped it. no noise now
probably not a problem for what you got
