humilde12a Posted January 4, 2005 Report Posted January 4, 2005 sup guys,happy new years to all,iam getting my head milled 30 over as iam writing, will i have to work with the carbs or it should be using the same jets iam using now? Quote
fixitrod Posted January 4, 2005 Report Posted January 4, 2005 I wouldn't say more jetting, I'd say more accurate jetting. If you're jetting right now, you'll be fine. Just do a plug check to make sure. Most of the time you won't have to do anything with jetting. Quote
Nightrider Posted January 4, 2005 Report Posted January 4, 2005 I agree jetting becomes more critical when higher cylinder pressures are achieved.The more accurate it is the less likely severe engine damage will occur. Your bike might run just fine on the lean side with low compression pressue,but jack it up and KABOOM! Quote
humilde12a Posted January 4, 2005 Author Report Posted January 4, 2005 thanks guys i'll do the plug check. Quote
Leadfoot350 Posted January 5, 2005 Report Posted January 5, 2005 I would say do a plug check too but a good rule of thumb is when you increase hp you have to increase fuel so you will need to go up on jets unless your old jetting was off. Quote
bansheecaptain Posted January 6, 2005 Report Posted January 6, 2005 i would go up one to be safe and try that and then do a plug chop, if i remember right i think i went up one also when i put my milled head on Quote
