Yep, the weather got cold and you didn't jet up. Is it a banshee? The stock yfz are know for that. They come a little lean. Header pipe will turn bright red.....not good.
299133[/snapback]
I thought that was how you could tell when it's warmed up! no need for a temp gauge
Just look at the plugs. If you see sparkly silver specs, then thats detonation. Don't ride it. If not, then you should be fine. Buy a compression tester and check your compression, that'll give you peace and mind and let you know where you stand. You should have one anyways. They only cost $20-50...Go back to B8ES. The 9's are just cooler..
