The shee was running fine earlier in the day, we got some snow and rain and freezing rain(this was while I drove it in the back of the truck). Then I take it out again when its a little colder(20's) and there is a lot of snow, let it warm up and all and it wants to bog down and stall whenever the powerband isnt kicked in. So it either bogs down or stalls. Dont know what the deal is. Any suggestions?, this is my first winter with it but I have heard of people runnig it in colder weather than this right? thanks in advance
Try raising your needle one notch, and you may want to give your airscrews a turn in or so depending on where they are set, maybe even go up one on the pilot. If you are running the same main jets in 20 degrees as in the summer time, you may want to go up possibly 2 sizes on those, you are probably running lean all the way around. :blink:
My shee was doing that exact same thing yesterday. my top end is fine, but it almost dies (bogs out) from 1/8 to 1/4 throttle. I am going to play with my airscrews, if that doesnt work I am going to throw in a 27.5 pilot.
i just moved my needles up one notch and i'm running 300 mains and it goes great fires right up every time, but i know if two stokes are "too good" they are to lean how can i tell if it's too lean, what sould the plugs look like? right now they are kind of a light coffee color, i just got it studded up for the ice i just don't want to burn it up :bolt:
297781[/snapback]
Depends on how much cream you use. ;)
I'd go for a Hershey chocolate color myself.
