My friend needs a left carb and I was thinking that a blaster carb might work since it is the same size. Will this setup work or not. I know that he would have to sincranize the carbs by how it felt because their is no window.
Yes it will work but check all jetting because blasters have bigger pilots, mains, and neddle valves, but i'm not sure if the slide and needle are the same or not.
The carb bodies are the same so the jets from one will fit the other
Edited by Tim C
no u cant just slap it on u have to change the jets around and drill out the port hole for the choke cross over tube. u can syn them in by taking the air filter off and adjust it accordingly
Edited by blaster105
  • Like 1
