Robstwin350 Posted December 13, 2004 Report Posted December 13, 2004 I did a compression test on my bike and i'm only comming up with 100 pounds something i'm doing is not right i know the bike has more than that. The instuctions say to crank five times to get a complete reading i followed directions but not sure if theres somthing eles i should be doing. Is there a trick to this that i dont know about please help.... Thanx in advance Quote
FIRST BANSHEE Posted December 13, 2004 Report Posted December 13, 2004 no tricks, just kick it untill it stops going up. about 5-10 times. Quote
superchicken Posted December 13, 2004 Report Posted December 13, 2004 r u holding the throttle wide open when kicking it over? Quote
Banshee17Racing Posted December 13, 2004 Report Posted December 13, 2004 yeah....I've been told that holding the throttle open when kicking makes a difference, I've never compared the difference. Just to make sure....you do have the tester tightened just like you would with spark plugs right? Quote
2stroke_addict Posted December 13, 2004 Report Posted December 13, 2004 I did a compression test on my bike and i'm only comming up with 100 pounds something i'm doing is not right i know the bike has more than that. The instuctions say to crank five times to get a complete reading i followed directions but not sure if theres somthing eles i should be doing. Is there a trick to this that i dont know about please help.... Thanx in advance 292440[/snapback] warm up the engine before testing, that should give you a more accurate reading. don't test compression on a cold engine. Quote
Robstwin350 Posted December 14, 2004 Author Report Posted December 14, 2004 THANKS FOR YOUR INPUT GUYS I WILL DEFINATELY TRY IT WIDE OPEN AND WARMED UP Quote
