Robstwin350
Contact Methods
  • Website URL
    http://
  • ICQ
    mesa,arizona
    2000 red & white,tommey t-5 pipes, ohton racing cool head/with a hill port, 4in.ext swingarm,alba a-arms-+2+1,timming advance +8,works shocks,hotrod crank ,wiesco pistons 65.5,dynod at 70 hp on gas with stock carbs
Robstwin350's Achievements
  1. it loses pwer on the left side almost like if it fouls the plug
  2. need help i rencently rebuilt my banshees top end after 7 years of nothing it was running slugish so i had top end redone. while it was apart i cleaned up the ports. nothing wild just made them smother and i did not touch the transfers only intake and exghaust. now it will start and idle fine but is blowing cold out the tailpipes. i have 300 main jet no v-force reeds and fmf fatty pipes also now my head lites wont turn on not sure if that makes a difference or not but if anyone can help with suggestions plzzzz do and thanks in advance
  3. THANKS FOR YOUR INPUT GUYS I WILL DEFINATELY TRY IT WIDE OPEN AND WARMED UP
  4. I did a compression test on my bike and i'm only comming up with 100 pounds something i'm doing is not right i know the bike has more than that. The instuctions say to crank five times to get a complete reading i followed directions but not sure if theres somthing eles i should be doing. Is there a trick to this that i dont know about please help.... Thanx in advance
  5. Can someone please define exzactly what is port timing and how to tell if, or by what marjine it is off, and the possibilities of port timing being off, and of couse what cuases it??? thanx guys.
  6. SDD, Now i have new cylinders ,head, carbs,stock bore, milledhead, 35mm pwk's with a moderate hill port or dune port call it what you will. My timing is advanced 5 degrees everthing is less than ten days old. Do you think its a CDI or timing problem i can't think of anything else because everything is new. I checked all of my bolts and gaskets for leeks twice over this baby is air tight, left side just wont fire as well as the right
  7. when i say i blew a plug i mean the plug melted once and the second time it just blew up, but did not blow a hole though my piston just damaged it and the cyilinder real bad. at the time of all of this i was running 66.5mm pistons and 17cc domes. Also i am running vp110 fuel as instructed by many builders because of compression, but i do not know what copression im running
  8. I had problems with my bike not fireing on the left side rebuilt it twice after blowing two sparkplugs same problem both times. now i have new cylinders and head, milded of corse also boutnew carbs 35mm pwk's finshed puting it together two days ago finaly started it today and just my luck same problem just not as bad. PLEASE someone point me in the right direction. My bike has a hill port stock bore 64mm weisco, pwk's35mm, v-force reeds, t-5 pipes, milled head, hot rod crank from the cases up is one week old AM I WASTEING MONEY???
  9. can somebody help me i have a toomey clutch kit with a after market clutch pusher and i cant find nuetral when the bike is runing. When i do find nuetral my bike still wants to roll forward what can i do about this.and yes i know that nuetral is between 1st and 2nd haha.....
