01bansheeke Posted December 7, 2004 Report Posted December 7, 2004 (edited) I just picked up some 34 mm carbs off of ebay. I need to know what all will need to run these. I have the throttle cable and the fuel lines. Do i need new intakes? will my old pod filters work or will I need to upgrade those too. Any help would be greatly appreciated. thanks! also need to get some baseline jetting. Right now i am running 370 mains on stock carbs..needle in 4th position with stock pilot(i believe). The carbs have 152 mains in them now. Edited December 7, 2004 by 01bansheeke Quote
Redlined Posted December 8, 2004 Report Posted December 8, 2004 You will need a new intake and new filters. As for jetting, start with what it has and test. You will probable go up in size. Filters: http://www.magicracing.com/product.asp?itemid=470&catid=170 Intake: http://www.magicracing.com/view_category.asp?cat=163 Just a place to start. I Quote
Blue Duece Posted December 8, 2004 Report Posted December 8, 2004 I need to know what all will need to run these. 290298[/snapback] i think you will need some jugs that can handle the added fuel and air..... Quote
Ducman Posted December 8, 2004 Report Posted December 8, 2004 What brand and model of 34mm carbs? Quote
Banchetta Posted December 10, 2004 Report Posted December 10, 2004 You'll need larger intakes from the cylinders to the carbs, larger filters or intake boots for the stock box. Your jetting should be around 175 main, 58 pilot and needle 4th clip from the blunt end w/ DEK needles. Quote
