Mod Banshee Posted December 3, 2004 Report Share Posted December 3, 2004 Ok I am doing some more Mods to my shee and I need some new Gearing. My Mods are. Passion 12 Port Stroker kit Cool Head w/21cc doms 33 PWKS Boss Intake V-Force Delta 2s Pro Flow Intake 6 Filtered air vents CPI Inframes Vitos Degree key lightened Flywheel Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate I Drag race in 300ft and trail Ride. What would be the Best Gearing for my Set up? Quote Link to comment Share on other sites More sharing options...
lonestar Posted December 3, 2004 Report Share Posted December 3, 2004 Ok I am doing some more Mods to my shee and I need some new Gearing. My Mods are.Passion 12 Port Stroker kit Cool Head w/21cc doms 33 PWKS Boss Intake V-Force Delta 2s Pro Flow Intake 6 Filtered air vents CPI Inframes Vitos Degree key lightened Flywheel Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate I Drag race in 300ft and trail Ride. What would be the Best Gearing for my Set up? 288163[/snapback] 15/40 Quote Link to comment Share on other sites More sharing options...
Mod Banshee Posted December 3, 2004 Author Report Share Posted December 3, 2004 I have been told to try a 14 or 15 Up Front with a 38 in the rear. What do you thank about the set up. Quote Link to comment Share on other sites More sharing options...
alcoholbanshee Posted December 3, 2004 Report Share Posted December 3, 2004 Every time I go to the track I bring 12-19t front sprockets and 33-45t rear sprockets. You really need to invest in some sprockets because what works today wont work tomorrow and vice versa! The only way to be fast is to change with the track. If you are going to be fast you will have to spend some money. There is no set up that works for all. Things just dont work that way. YOU HAVE TO FIND WHAT WORKS FOR YOU!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted December 3, 2004 Report Share Posted December 3, 2004 exactly....for 300 ft. i wouldn't get less than a 42 on the rear...Just dial in your countershaft sprocket. Quote Link to comment Share on other sites More sharing options...
jab90 Posted January 2, 2005 Report Share Posted January 2, 2005 what is a good size rear tire to run when drag racing? 20in or 22in tire? i have a 13 front and 40 rear gear. thanks Quote Link to comment Share on other sites More sharing options...
FlatTrackinIt55 Posted January 3, 2005 Report Share Posted January 3, 2005 what is a good size rear tire to run when drag racing? 20in or 22in tire? i have a 13 front and 40 rear gear. thanks 300727[/snapback] ID GO WITH 20 Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted January 3, 2005 Report Share Posted January 3, 2005 for drag racing the 22 is much better if you have the horsepower to turn it. Quote Link to comment Share on other sites More sharing options...
