+2 + 1 = +3  in algebaric terms
287574[/snapback]
actually, the diference would be most noticable in trig. whereas 2" out and 1" forward would put the new pivot root 5 inches away from the original position. then the spindle mounts would lie in a position 116.565* away from the original. of couse that is for the left side. the right side would remain the same distance away from the origin as one the left, but would then lie at the position 26.565*.
That make sense to everyone?
287574[/snapback]
287580[/snapback]
:whoa::wacko: ENGLISH PLEASE! the hell withit. I gonna go to bed and think about that 1... :unsure:
Edited by banshee76179
The first number (+2) is width and the second number (+1) is the forward. If there is only one number, it means it's only that width wider and no forward.
+2+1 = 2" wider and 1" forward
+1 = 1" wider only.
I'd get +2+1's. The one inch forward helps the front end stability and helps move weight where it's needed.
287580[/snapback]
Nice work bro! :cheers:
I recently put +2+1 on and works shocks, lsr axle and it feels like a totoaly different bike alot more stable now. I need to get my rear shock redone though.
287906[/snapback]
And shorten your swinger 2"!!! :headbang:B)
