lineybiker_11 Posted December 1, 2004 Report Posted December 1, 2004 hi i was wondering what size aftermarket carbs i should get for my shee? I know i'm goin to ge makuni tm flatsliders because i work at a harware store that sell alot of parts and i can get them at cost. i was just wondering on what size i should order i have mild porting bored 20 over milled head and sst's coming i'm also going to order boysen rad valve and a billet intake i also plan on having more porting mods done too. i just want your opinion thanks Quote
fixitrod Posted December 1, 2004 Report Posted December 1, 2004 Depending on your porting 28mm or 30mm max. Ask the builder that you are thinking of using. I personally wouldn't buy boyesen rad valves. Put your money in delta's or pyramids. Quote
Banchetta Posted December 2, 2004 Report Posted December 2, 2004 Depending on your porting 28mm or 30mm max. Ask the builder that you are thinking of using. I personally wouldn't buy boyesen rad valves. Put your money in delta's or pyramids. 287374[/snapback] What he said..... Quote
FIRST BANSHEE Posted December 2, 2004 Report Posted December 2, 2004 Depending on your porting 28mm or 30mm max. Ask the builder that you are thinking of using. I personally wouldn't buy boyesen rad valves. Put your money in delta's or pyramids. 287374[/snapback] What he said..... 287563[/snapback] Thats why there legends. Quote
Banchetta Posted December 4, 2004 Report Posted December 4, 2004 Depending on your porting 28mm or 30mm max. Ask the builder that you are thinking of using. I personally wouldn't buy boyesen rad valves. Put your money in delta's or pyramids. 287374[/snapback] What he said..... 287563[/snapback] Thats why there legends. 287723[/snapback] Rod is just a post whore..... Quote
