mines got FMf fatties...open k/n..boysen reeds, bored 3 times over,tors elimtaor kit on 93octane. we went out yesterday and it smoked bad on start up. it ran ok after warmed up, but still bogged alil...it still smoked pretty good after warm, and it was spewing coolant more htan normal....the coolant and power thing make me think its lean, but then it was smoking alot...and from what ive read int he posts here, im supposed to go upin mains in the winter. its jetted for like 75 right now,and yeterday was only like 55F. well, it gets down to like 0 here and i still ride. i have 280 mains, neddle is on hte second clip, pilot screw is 1.5 out(stock) and i cant member what the piolet jet is at. they are stock carbs still witha twist throttle...any ideas.......... :cry:
ohh,a nd did we ever find out from last yr what makes the slides stick on stock carbs in the winter, or if there was a good fix for it? :confused:
thanks... banghead
ohh, and since i forgot bout checkin the plugs.. i know there knew just a few mothsn ago, and they r the gold series NGK, whatever my racer friends run..and it starts fine, idles fine..it just bogs a lil thru the whole throttle,a nd really noticeable in the begging of the powerband. once it gets really up htere, i dont seem to notice much of a problem.. it seems like i need to lean it out, but i thought for winter it should go rich. it does require the choke to start it still..so idk.
please help :cry:
