BradDaMan Posted November 16, 2004 Report Posted November 16, 2004 I just bought a 97 banshee and I have noticed that its harder to shift compared to my friends banshee. you have to pull up harder to shift up, any ideas? it is a little difficult to get into neutral too. Its got a dirt digger clutch correctly adjusted, shifts in all gears just a little harder to pull. Quote
dynabanshee Posted November 16, 2004 Report Posted November 16, 2004 If everything is mechanically sound, maybe do a shift star mod. It makes the shift stat less peaky so it rolls into place easier. Quote
sredish Posted November 16, 2004 Report Posted November 16, 2004 Have you changed the tranny fluid? Not saying this is definitely the cause, but the fluid could be old or not a very good brand or something and that can make gear engagement a little more difficult. I'd change the fluid and get a recommended brand. I personally run Silkolene Comp Gear designed for that type of application. You need something that will lubricate and also dissipate the heat of a wet clutch. Quote
BradDaMan Posted November 16, 2004 Author Report Posted November 16, 2004 Have you changed the tranny fluid? Not saying this is definitely the cause, but the fluid could be old or not a very good brand or something and that can make gear engagement a little more difficult. I'd change the fluid and get a recommended brand. I personally run Silkolene Comp Gear designed for that type of application. You need something that will lubricate and also dissipate the heat of a wet clutch. 281484[/snapback] The previous owner stated he used Gear Saver. I did the finger test and it looked freshly changed. Might need to do another change just to be sure. Quote
fixitrod Posted November 16, 2004 Report Posted November 16, 2004 You might just need a shift shaft adjustment. Get a clymers manual for sure. It will save you a ton of money in the long run!!! Quote
BenBB Posted November 16, 2004 Report Posted November 16, 2004 Right on Fixitrod, BTW my shift shaft had just skipped on the shift star nubs, just had to pull the clutch cover & shift lever to move it out a little and it recentered. Anyway, BradDaMan, this might not be relavent, but there's an outside chance that just moving the shift lever up or down a spline will improve your shifting (of course it won't if something is fucked up inside). From what you described it almost sounds like the shaft itself may be bent and gets in a bind sort of when you try to shift... Quote
BradDaMan Posted November 17, 2004 Author Report Posted November 17, 2004 Right on Fixitrod, BTW my shift shaft had just skipped on the shift star nubs, just had to pull the clutch cover & shift lever to move it out a little and it recentered. Anyway, BradDaMan, this might not be relavent, but there's an outside chance that just moving the shift lever up or down a spline will improve your shifting (of course it won't if something is fucked up inside). From what you described it almost sounds like the shaft itself may be bent and gets in a bind sort of when you try to shift... 281731[/snapback] The shift lever was broke and looked to be welded up. I think I will just move it a click and see if that helps until I get a replacement. Thanks!!!!!!! Quote
