OK, just about done with the shee. The chain was too long when I first installed it, so I took a link off (which is actually 2) now it is about 1/8th inch too short. I was running a 45 rear sprocket, and now ordered a 42 to split the difference, think itll work out??
279617[/snapback]
Yea, when you put on the 42T sprocket you should be OK.
If not, I have seen swingarms modified where you remove the axle carrier and make the slots longer that the bottom bolt rides in. Just use a Dremel and grind the slot about a 1/2" further towards the front of the swingarm. Try to maintain the same arc/radius that is already there. I have used a swingarm that was modified like this before with no problems.
