On my 94 if it has been sitting for a bit the brakes are really spongy. I'm thinking I have to bleed the system. Is it basically the same as a car? Basically the front res. is for the front brakes and the rear for the rear brake. I must have an air leak somewhere, I dont see fluid anywhere under the shee but the brakes do get fucked up after a sitting period.
It IS like bleeding a car, but much easier. I'd replace all the fluid with new DOT4, you can get a vacuum to suck out the fluid from Auto Zone for around $20, or you can just pump it all out. But yes, the front handlebar-mounted rez is for the front two and the rear brake has it's rez behind the right rear-brake lever.
Later.
If it still feels spongy after you bleed the brakes, front or rear. check the rubber lines, they will expand under hard braking espeically if there starting to rot. braided lines make your brakes work much better
I agree with both previous posts, especially sredish's. You need to change the brake fluid every few years. Brake fluid is hydroscopic and absorbs water over time, which, along with causing soft feeling brakes, causes the internal brake components to corrode.
All the above post's have you headed in the right direction, just wanted to add that a "Mityvac" will turn it into a 1 man job, create less mess, and take about 5 minutes.
  • 2 weeks later...
I recently added steel braided lines. everything seems to be working but still can't get any resistance on the lever. no leaks no more air (bubbles), fluid comes out of the bleeders when I crack it open -w/ tube looped and submerged into container of fluid. I think I need to get one of those pumps.I've pumped this frekin lever so much that now I know my sex life / brakes will be gone for atleast a week. any advice? (on the brakes j/k about the other thing)
Sometimes it just takes patience to get all the air out. With my line change I almost had to run a qt of brake fluid through the lines before they started working. ;)
Thanks! that's what it took. 2 hours of it. next time I think I will get a pump to the bleeder. It was such a good feeling when the lever finally stiffened up. I kept thinking that I was drawin' air from the m/c.
