I was wondering if i should do a tune up be for winter. If so what should i do cause im ganna ride it in the winter. Is there special fluids i need to put in or anything like that.? Im new to the banshee and havent even had it a full year yet so i dont know what to do .
thanks in advance for the help
If you have pipes and mods you may need to go up a size or 2 on the main jets to compensate for cold air temps which can cause your motor to run lean. On a all stock bike it may not be as noticeable or as necessary but still should be considered.
if the engines been rebiult most likely youve got wiseco pistons in her.there forged not cast and expand quicker than the cylinders during warmup.if you do have them let her warm up a little longer before you romp on it or you'll get a cold seizure,not good.other than that no specail fluids,but make sure your anti freeze is mixed 50/50 or you can get cracked cylinders if it freezes over
