sandslinger03 Posted October 20, 2004 Report Posted October 20, 2004 How would you go about checking for an air leak. What would be the simplest way to find out if I have one and where it is? Quote
Big Blue Posted October 20, 2004 Report Posted October 20, 2004 spray carb cleaner around your intake boots while the bike is running and you will be able to tell. Quote
FIRST BANSHEE Posted October 21, 2004 Report Posted October 21, 2004 If your crank seals are bad it will be hard to tune, itwill seem like your jetting is off. If the clutch side is bad I believe you will suck oil,and foul plugs, if the stator side is bad, you will run lean, if there both bad combine the two. Quote
