MudSlinger09 Posted October 8, 2004 Report Posted October 8, 2004 hey is a set of fmf gnarly pipes good 4 blazing in the woods and can they withstand some mud ? you guys should know Quote
2004LEBanshee Posted October 9, 2004 Report Posted October 9, 2004 I got fatty's which are pretty much the same thing. I think there great trail pipes. Thats all I ride. Quote
Banshee~ Posted October 9, 2004 Report Posted October 9, 2004 do you even have a banshee? use the search button in top right corner Quote
banshee76179 Posted October 9, 2004 Report Posted October 9, 2004 I run gnarlys good all around pipe, If not fatties gives U a around good power curve..can't go wrong w/either Quote
Banshee~ Posted October 9, 2004 Report Posted October 9, 2004 I run gnarlys good all around pipe, not really there a low end only pipe....they actually make you slower on top end..fattys are the all around fmf pipe Quote
roosthrower Posted October 10, 2004 Report Posted October 10, 2004 I can tell you right now a gnarly piped banshee would whoop the crap out of a stock piped banshee. Quote
banshee76179 Posted October 10, 2004 Report Posted October 10, 2004 I run gnarlys good all around pipe, not really there a low end only pipe....they actually make you slower on top end..fattys are the all around fmf pipe If not fatties gives U a around good power curve Quote
Banchetta Posted October 11, 2004 Report Posted October 11, 2004 If your shee w/ gnarlies is slower on top, then you better have someone else redo your jetting..... Quote
fixitrod Posted October 11, 2004 Report Posted October 11, 2004 hey is a set of fmf gnarly pipes good 4 blazing in the woods and can they withstand some mud ? you guys should know Yes and yes!! Quote
