Bansheeman1121 Posted October 5, 2004 Report Posted October 5, 2004 Can i mill the main piece of my noss head anywhere from 10 to 30 thousanths?? Quote
racer Posted October 5, 2004 Report Posted October 5, 2004 im no dave noss but why the well would you want to do that? Quote
Bansheeman1121 Posted October 5, 2004 Author Report Posted October 5, 2004 Stupid me marked my head up by prying it off, i got the base plate brand new, im just gettin my banhsee all fixed and wanna oput my noss head back on so im just worried she wont seal with the coupple of dents i put in it, so milling it would be a easy fix Quote
racer Posted October 5, 2004 Report Posted October 5, 2004 yeah after posting i considered that in my head. try sending him a PM you may get a little more detailed response. Quote
dlnoss Posted October 5, 2004 Report Posted October 5, 2004 Milling it will make something not fit. Depending on where it's cobbed up it might not hurt the seal. You can sand it on a flat surface or even run a fine file across it to knock off any burrs or you can send it to me and I'll check it out. If it is along the outside edge and it doesn't extend in as far as the oring groove, smoothing it out will probably be fine. Let me know if you need any help with it. -David Quote
sredish Posted October 5, 2004 Report Posted October 5, 2004 you can send it to me and I'll check it out. that sounds like the smart move right there. i don't think i'd be trying to shave, cut, file, or as Dave puts it, cobb on my head, i'd let the maker do it. Quote
Bansheeman1121 Posted October 5, 2004 Author Report Posted October 5, 2004 I work in a machine shop everyday so i got every tool, machine availible to me so i think ill take her to the sander just to make sure, i was just tepmted to put her in the cnc Quote
