alright guys need some info on jetting ,shee is a bitch to start cold but when warmed up she fires on first kick but has a bog promblem about 1/4 throttle on ,My mods are fmf sst. exaust,k&n filter,air box lid removed 280 main 27.5 on pilot fmf carbon fiber reeds and Pa. elavation anybody have any suggestions?
Do you use the choke to start it when cold and when hot, or not at all? Does it require the choke to start warm? Have you had any problems with your choke circuit? You might try a 30 pilot and see if that helps. What clip is your needle on? It should probably be on the 4th from the top/blunt end. If the needle is in the 3rd, I'd recommend to change the clip to the 4th and try it. If it's not fixed, then go to a 30 pilot and see how that works.
Let us know.
Edited by sredish
